Tanımlama
D-Link’s new generation DXS-F3500-32S switch delivers a versatile feature set, High-density port count in 1U rack mount size; suitable for Data Center TOR or Enterprise & campus environments CORE/Aggregation requirements. The DXS-F3500-32S A non-blocking architecture design provides high-performance L2/L3/L4 switches feature wire-speed switching capacity of 10/40 Gigabit Ethernet switching, routing at ultra-low latency. DXS-F3500-32S provides 4 x 1000BASE-T ports, 24 x 1/10GbE SFP/SFP+ ports ports, 2 x 40G QSFP+ Ports in compact 1U rack size.
High Availability & Flexibility
The DXS-F3500-32S switch features a modular fan and power supply design for a high availability architecture. The hot-swappable design means that fans and power supplies can be replaced without affecting switch operation. The Multi-Chassis Trunking enables multiple DXS-F3500-32S switches to be configured in a Virtual chassis and can provide non-stop layer-3 routing forwarding even in case of failure of any switch in the virtual chassis.
Lossless Ethernet
Data Center Bridging (DCB) is an essential set of enhancements to Ethernet for networking in data center environments. The DXS-F3500-32S switch support several core components of Data Center Bridging (DCB) such as IEEE 802.1Qbb, IEEE 802.1Qaz, and IEEE 802.1Qau. IEEE 802.1Qbb (Priority-based Flow Control) provides flow control on specific priority to ensure there is no data-loss during network congestion. IEEE 802.1Qaz (Enhanced Transmission Selection) manages the allocation of bandwidth amongst different traffic classes. IEEE 802.1Qau (Congestion Notification) provides congestion management for data flows within network domains to avoid congestion.
Genel Özellikler
Interfaces 4 x 1000BASE-T ports, 24 x 1/10GbE SFP/SFP+ ports ports, 2 x 40G QSFP+ Ports
Hardware Version A1
Media Interface Exchange Auto or configurable MDI/MDIX
Console Port RJ-45 and Mini USB console ports for out-of-band CLI management
Management Port 10/100/1000BASE-T RJ-45 Ethernet for out-of-band IP management
USB Port A-Type Port
Performance
Switching Capacity 640 Gbps
Max. Forwarding Rate 480 Mpps
Packet Buffer Memory 9M
MAC Address Table 128K
Physical
Power input
Dual Redundant AC Power supplies (100 to 230 V AC)
Dual Redundant DC Power supply 36V ~ 72V (Available on request)
Dimensions
442×404×44 mm (W x D x H) 1U
Operating Temperature 0° to 50° C
Storage Temperature -20° to 70° C
Operating Humidity 10%-90% non-condensing
Storage Humidity 5%-95% non-condensing
Certifications
Safety RoHS
