DWR-980
Wireless AC1200 Wave 2 MU-MIMO 4G LTE Router with VDSL2 Support, Gigabit Ethernet Ports, 2 FXS Ports, and USB Port
Tanımlama
Built-in LTE Modem
The router is equipped with a built-in LTE modem which provides 3G/4G mobile connection with fast downlink speeds of up to 150Mbps and uplink speeds of up to 50Mbps.1
DSL Port, 4-port Switch, and Gigabit Ethernet WAN Port
The router is equipped with a DSL port to connect to a high-speed VDSL line. The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network. In addition, Gigabit Ethernet WAN port enables you to connect the device to a high-speed Ethernet line.
USB Port
The router is equipped with a USB port for connecting a USB modem, which can be used to establish additional mobile connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
In order to use the multifunction USB port effectively, the router supports simultaneous operation of several USB devices. For example, you can access multimedia content of the connected HDD storage and at the same time share a USB printer.2
Wireless Interface
Using the DWR-980 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 1167Mbps3).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2/WPA3), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Multi-user MIMO technology allows to distribute the router's resources to let multiple wireless clients use the Wi-Fi network efficiently, keeping high rates for HD media streaming, lag-free gaming, and fast transfer of large files.
Transmit Beamforming technology allows to flexibly change the antennas' radiation pattern and to redistribute the signal directly to wireless devices connected to the router.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Voice
The device is equipped with two FXS ports which allow connection of analog phones for calls via Internet.
Security
The wireless router DWR-980 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
The SSH protocol support provides more secure remote configuration and management of the router due to encryption of all transmitted traffic, including passwords.
In addition, the router supports IPsec and allows to create secure VPN tunnels. Support of the IKEv2 protocol allows to provide simplified message exchange and use asymmetric authentication engine upon configuration of an IPsec tunnel.
The router also supports the SkyDNS web content filtering service, which provides more settings and opportunities for safer Internet experience for home users of all ages and for professional activities of corporate users.
Now the schedules are also implemented; they can be applied to the rules and settings of the firewall and used to reboot the router at the specified time or every specified time period, to automatically save the configuration of the router to a connected USB storage, to set rules for limitation of wireless client maximum bandwidth, and to enable/disable the wireless network and the Wi-Fi filter.
Easy configuration and update
You can configure the settings of the wireless router DWR-980 via the user-friendly web-based interface (the interface is available in several languages).
The configuration wizard allows you to quickly switch DWR-980 to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
Also DWR-980 supports configuration and management via mobile application for Android smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1Data rates are theoretical. Data transfer rate depends on network capacity and signal strength.
2When using a USB hub with external power supply.
3Up to 300Mbps for 2.4GHz and up to 867Mbps for 5GHz.
Genel Özellikler
				 Hardware
				 Processor
				 • RTL8685PB (1GHz)
				 RAM
				 • 128MB, DDR2, built in processor
				 Flash
				 • 128 МБ, Serial NAND
				 Built-in modem
				 • BroadMobi BM806U-E1
				 Interfaces
				 • Slot for SIM card (mini-SIM)
				• 10/100/1000BASE-T WAN port
				• 4 10/100/1000BASE-T LAN ports
				• 1 RJ-11 DSL port
				• 2 RJ-11 FXS ports
				• USB 2.0 port
				 LEDs
				 • POWER
				• INTERNET
				• WAN
				• LAN
				• 5GHz
				• 2.4GHz
				• VOICE
				• DSL
				• SMS
				• 3G/LTE
				• SIGNAL STRENGTH
				 Buttons
				 • POWER switch to power on/power off
				• RESET button to restore factory default settings
				• WPS button to set up wireless connection
				• WIFI ON/OFF button to enable/disable wireless network
				 Antenna
				 • Two detachable LTE/3G antennas (3dBi gain)
				• Two SMA Female connectors for LTE/3G antennas
				• Two internal Wi-Fi antennas for 2.4GHz band (4dBi gain)
				• Two internal Wi-Fi antennas for 5GHz band (4dBi gain)
				 MIMO
				 2 x 2, MU-MIMO
				 Power connector
				 • Power input connector (DC)
				 Mounting
				 • Desktop
				 Software
				 WAN connection types
				 • Mobile Internet (via built-in modem and/or supported external USB modem)
				• PPPoE / IPv6 PPPoE / PPPoE Dual Stack / PPPоA
				• Static IPv4 / Dynamic IPv4 / IPoA
				• Static IPv6 / Dynamic IPv6
				• PPPoE + Static IP (PPPoE Dual Access)
				• PPPoE + Dynamic IP (PPPoE Dual Access)
				• PPTP/L2TP + Static IP
				• PPTP/L2TP + Dynamic IP
				 Network functions
				 • DHCP server/relay
				• Advanced configuration of built-in DHCP server
				• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
				• Automatic obtainment of LAN IP address (for access point/repeater/client modes)
				• DNS relay
				• Dynamic DNS
				• Static IPv4/IPv6 routing
				• IGMP Proxy
				• RIP
				• Support of UPnP
				• Support of VLAN
				• WAN ping respond
				• Support of SIP ALG
				• Support of RTSP
				• WAN failover
				• LAN/WAN conversion
				• Autonegotiation of speed, duplex mode, and flow control / Manual speed and duplex mode setup for each Ethernet port
				• Built-in UDPXY application
				• Equal load distribution while using several WAN connections (traffic balancing)
				• Port mirroring
				• Wake-on-LAN support
				 Firewall functions
				• IPv4/IPv6 filter
				• MAC filter
				• URL filter
				• DMZ
				• Prevention of ARP and DDoS attacks
				• Virtual servers
				• Built-in SkyDNS web content filtering service
				 VPN
				• PPTP/L2TP servers
				• PPTP/L2TP tunnels
				• L2TP over IPsec client
				• GRE/EoGRE/EoIP tunnels
				• IPsec tunnels
				• Transport/Tunnel mode
				• IKEv1/IKEv2 support
				• DES encryption
				• NAT Traversal
				• Support of DPD (Keep-alive for VPN tunnels)
				 QoS
				 • VLAN priority (802.1p)
				 USB interface functions
				 • USB modem
				  - Auto connection to available type of supported network (4G/3G/2G)
				  - Auto configuration of connection upon plugging in USB modem
				  - Enabling/disabling PIN code check, changing PIN code1
				  - Sending/receiving/reading/removing SMS messages1
				  - Support of USSD requests1
				• USB storage
				  - File browser
				  - Print server
				  - Access to storage via accounts
				  - Built-in Samba/FTP/DLNA server
				  - Built-in Transmission torrent client; uploading/downloading files from/to USB storage
				 Management and monitoring
				 • Local and remote access to settings through SSH/TELNET/WEB (HTTP/HTTPS)
				• Multilingual web-based interface for configuration and management
				• Support of D-Link Assistant application for Android smartphones
				• Support of logging to remote host/connected USB storage
				• Ping utility
				• Traceroute utility
				• TR-069 client
				• Schedules for rules and settings of firewall, automatic reboot and saving a configuration backup to a connected USB storage, limitation of wireless client maximum bandwidth, and enabling/disabling wireless network and Wi-Fi filter
				• Automatic upload of configuration file from ISP's server (Auto Provision)
				• Configuration of action for hardware buttons
				 LTE Module Parameters
				 LTE connection rate2
				 • Downlink: up to 150Mbps
				• Uplink: up to 50Mbps
				 Supported frequencies3
				 • Power Class 3
				• LTE
				  - Band: TX / RX
				  - B1: 1920~1980MHz / 2110~2170MHz
				  - B2: 1850~1910MHz / 1930~1990MHz
				  - B3: 1710~1785MHz / 1805~1880MHz
				  - B5: 824~849MHz / 869~894MHz
				  - B7: 2500~2570MHz / 2620~2690MHz
				  - B8: 880~915MHz / 925~960MHz
				  - B20: 832~862MHz / 791~821MHz
				  - B38: 2570~2620MHz / 2570~2620MHz
				  - B40: 2300~2400MHz / 2300~2400MHz
				• UMTS
				  - B1/2/3/5/8 (2100/1900/1800/850/900MHz)
				• GSM/GPRS
				  - 850/900/1800/1900MHz
				 Functions
				 • Auto connection to available type of supported network (4G/3G/2G)
				• Auto configuration of connection upon plugging in SIM card
				• Enabling/disabling PIN code check, changing PIN code
				• Sending/receiving/reading/removing SMS messages
				• Support of USSD requests
			(For DWR-980 with the built-in modem FW version M1.4.4_E1.0.3_A1.1.8. See the data on the modem FW version in the web-based interface of the router, on the “USB Modem” page.)
				 DSL Parameters
				 VDSL/ADSL Standards
				 • VDSL2: ITU G.993.2, support of 8a, 8b, 8c, 8d, 12a, 12b, 17a, 30a, 35b
				• ADSL: Multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G.hs)
				• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A/L/M, ITU-T G.992.4 (G.lite.bis) Annex A
				• ADSL2+: ITU-T G.992.5 Annex A/L/M
				• ITU-T G.993.5 (G.vector)
				• ITU-T G.998.4 (G.inp)
				 ATM/PPP Protocols
				 • Bridged and routed Ethernet encapsulation
				• VC-based or LLC-based multiplexing
				• ATM Forum UNI3.1/4.0 PVC (up to 8 PVCs)
				• ATM Adaptation Layer Type 5 (AAL5)
				• ITU-T I.610 OAM F4/F5 loopback
				• ATM QoS
				• PPP over ATM (RFC 2364)
				• PPP over Ethernet (PPPoE)
				• Keep-alive for PPP connections
				 Wireless Module Parameters
				 Standards
				 • IEEE 802.11ac Wave 2
				• IEEE 802.11a/b/g/n
				• IEEE 802.11k/v
				• IEEE 802.11w
				 Frequency range
				The frequency range depends upon the radio frequency regulations applied in your country
				 • 2400 ~ 2483.5MHz
				• 5150 ~ 5350MHz
				• 5650 ~ 5850MHz
				 Wireless connection security
				 • WEP
				• WPA3 (Personal)
				• МАС filter
				• WPS (PBC/PIN)
				 Advanced functions
				 • Support of client mode
				• WMM (Wi-Fi QoS)
				• Information on connected Wi-Fi clients
				• Advanced settings
				• Smart adjustment of Wi-Fi clients
				• Guest Wi-Fi / support of MBSSID
				• Rate limitation for wireless network/separate MAC addresses
				• Periodic scan of channels, automatic switch to least loaded channel
				• Support of 2.4GHz/5GHz TX Beamforming
				• Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
				• Support of STBC
				• CoovaChilli authentication portal
				 Wireless connection rate
				 • IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11n (2.4GHz/5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15)
				• IEEE 802.11ac (5GHz): from 6.5 to 867Mbps (from MCS0 to MCS9)
				 Transmitter output power
				 • 2.4GHz
				Less than 19dBm (79.4mW)
				• 5GHz
				Less than 20dBm (100mW)
				 Receiver sensitivity
				 • 802.11a
				-82dBm at 6Mbps
				• 802.11b
				-80dBm at 1Mbps
				• 802.11g
				-82dBm at 6Mbps
				• 802.11n
				-82dBm at MCS0/8
				• 802.11ac
				-76dBm at MCS0
				 Modulation schemes
				 • 802.11a: BPSK, QPSK, 16 QAM, 64 QAM with OFDM
				• 802.11b: DQPSK, DBPSK, DSSS, and CCK
				• 802.11g: BPSK, QPSK, 16QAM, 64 QAM with OFDM
				• 802.11n: BPSK, QPSK, 16 QAM, 64 QAM with OFDM
				• 802.11ac: BPSK, QPSK, 16 QAM, 64 QAM, 256 QAM with OFDM
				 Phone
				 General SIP Features
				 • Support of several SIP profiles
				• Individual account per port
				• Invite with Challenge
				• Register by IP address or domain name of SIP server
				• Backup proxy support
				• Support of DHCP option 120
				• RFC3986 SIP URI format support
				• Outbound proxy support
				• STUN client
				• NAT public IP address
				• NAT keep-alive
				• Session timer (re-invite/update)
				• Call types: voice/modem/fax
				• User programmable Dial Plan
				• Manual peer table (for P2P calls)
				• Handling numbers in E.164 format
				 Call Features
				 • Direct IP-to-IP сall without SIP proxy (P2P)
				• Call hold/retrieve
				• Call awaiting
				• Forwarding (unconditional, busy, no answer)
				• Do Not Disturb
				• Blocking hidden number calls
				• CLIR
				• Speed/abbreviated dialing
				• PIN code before dialing
				• Phone book
				• Hotline
				• Vertical service codes
				• Intercom (internal calls without SIP server)
				• Filtering SIP packets by IP address/domain name (white/black list)
				• Alarm clock
				• Logging calls
				 Voice Features
				 • Codecs: G.711 a/μ-law, G.729A, G.726, G.722, G.723.1
				• DTMF detection and generation
				• In-band DTMF, out-of-band DTMF (RFC2833, SIP-INFO)
				• Comfort Noise Generation (CNG)
				• Voice Activity Detection (VAD)
				• Dynamic Jitter Buffer
				• Echo Cancellation (LEC/NLP)
				• Call progress tone generation (FXS)
				• DTMF/PULSE dial support
				• Caller ID detection and generation
				• T.30 FAX bypass to G.711, T.38 Real Time FAX Relay, V.152
				• Adjustable Flash Time
				• Advanced call transfer, three-party calls
				• Volume control (speaker/microphone)
				 Physical Parameters
				 Dimensions (L x W x H)
				 • 220 x 67 x 195 mm (8.7 x 2.6 x 7.7 in)
				 Weight
				 • 465 g (1 lb)
				 Operating Environment
				 Power
				 • Output: 12V DC, 2.5A
				 Temperature
				 • Operating: from 5 to 40 °C
				• Storage: from -20 to 70 °C
				 Humidity
				 • Operating: from 10% to 90% (non-condensing)
				• Storage: from 5% to 95% (non-condensing)
				 Delivery Package
				 • Router DWR-980
				• Power adapter DC 12V/2.5A
				• Ethernet cable
				• RJ-11 telephone cable
				 Supported USB modems4
				 GSM
				 • Alcatel X500
				• D-Link DWM-152C1
				• D-Link DWM-156A6
				• D-Link DWM-156A7
				• D-Link DWM 156A8
				• D-Link DWM-156C1
				• D-Link DWM-157B1
				• D-Link DWM-157B1 (Velcom)
				• D-Link DWM-158D1
				• D-Link DWR-710
				• Huawei E150
				• Huawei E1550
				• Huawei E156G
				• Huawei E160G
				• Huawei E169G
				• Huawei E171
				• Huawei E173 (Megafon)
				• Huawei E220
				• Huawei E3131 (MTS 420S)
				• Huawei E352 (Megafon)
				• Huawei E3531
				• Prolink PHS600
				• Prolink PHS901
				• ZTE MF112
				• ZTE MF192
				• ZTE MF626
				• ZTE MF627
				• ZTE MF652
				• ZTE MF667
				• ZTE MF668
				• ZTE MF752
				 LTE
				 • Alcatel IK40V
				• Brovi E3372-325
				• D-Link DWM-221
				• D-Link DWM-222
				• D-Link DWR-910 (revision D1)
				• Huawei E3131
				• Huawei E3272
				• Huawei E3351
				• Huawei E3372s
				• Huawei E3372h-153
				• Huawei E3372h-320
				• Huawei E367
				• Huawei E392
				• Megafon M100-1
				• Megafon M100-2
				• Megafon M100-3
				• Megafon M100-4
				• Megafon M150-1
				• Megafon M150-2
				• Megafon M150-3
				• Megafon M150-4
				• Quanta 1K6E (Beeline 1K6E)
				• MTS 824F
				• MTS 827F
				• MTS 830FT
				• Yota LU-150
				• Yota WLTUBA-107
				• ZTE MF823
				• ZTE MF823D
				• ZTE MF827
				• ZTE MF833T
				• ZTE MF833V
				• ZTE MF79U
				 Smartphones in USB tethering mode
				 • Some models of Android smartphones
1For some models of USB modems.
2Data rates are theoretical. Data transfer rate depends on network capacity and signal strength.
3Supported frequency bands are dependent on regional variants.
4The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Çözümler
Sipariş Bilgisi
DWR-980  Wireless AC1200 Wave 2 MU-MIMO 4G LTE Router with VDSL2 Support, Gigabit Ethernet Ports, 2 FXS Ports, and USB Port
