DCS-8000LH
Mini HD Wi-Fi Camera
Nereden Alınır
Tanımlama
DCS-8000LH
Meet the Mini HD Wi-Fi Camera.
Your second set of eyes around the home or office.
D-link
D-link
D-link
D-link
D-link
D-link
D-link
D-link
Home security in high definition.
Crisp HD 720p video gives you a clear view of what's going on at home. See more of your faces and places -- it's home monitoring with an eye for detail.
With a 120° wide angle lens, you can see more of your rooms, pets and kids.
D-link
Night Vision
See your home, even in complete darkness, so that you know what’s happening at home 24/7.
Simple Setup
Setting up the camera quick and easy with the mydlink Lite app. Simply download and install the app on your smartphone or tablet and follow the step-by-step instructions. You can also set up the camera using Bluetooth.
Peace of Mind, Wherever You Are with mydlink
With the mydlink app, you can easily monitor your home and look after what’s important to you, while you are away. Receive notifications and check-in on those you love at any time. You can even record precious moments directly to the cloud onto your phone or through the mydlink app.
  • iTunes App StoreGoogle Play Store
D-link
D-link
Good things come in small packages.
Despite its small size, the Mini HD Wi-Fi Camera has all the features you need for monitoring your home.
Easier than ever to set up.
Get your DCS-8000LH set up in minutes with Bluetooth 4.0, and place it just about anywhere in your home. Easily add cameras to cover new spaces and new additions.
D-link
What's in the Box
D-link
HIGHLIGHTS
Functions & Features
Camera
Hardware Profile
  • One-megapixel progressive CMOS sensor
  • Minimum object distance: 50 cm
  • Lens focal length: 2.45 mm ± 3%
  • Aperture: F2.4
  • Built-in Infrared-Cut Removable (ICR) Filter
  • Built-in microphone
  • Angle of view:
    • Horizontal: 112°
    • Vertical: 54°
    • Diagonal: 120°
  • 4x Digital zoom
  • 5 metre IR illumination distance
Image Features
  • Time stamp and text overlays
  • Configurable sound detection level
  • Configurable motion detection windows
  • Configurable brightness
Video Compression
  • Simultaneous H.264 format compression
  • JPEG for still images
Video Resolution
  • 1280 x 720 at up to 30 fps
Audio Support
  • PCM
Network
Connectivity
  • 2.4 GHz: 802.11n/g wireless with WPA/WPA2 encryption
Network Protocols
  • IPv4, ARP, TCP, UDP, ICMP
  • NTP client (D-Link)
  • DNS client
  • RTP/RTSP/RTCP
  • Bonjour
Features
Event Management
  • Motion detection
  • Sound detection
Video/Image Recording
  • Manually taken snapshots & video clips are saved to mobile device1
Browser  Support
  • Windows OS running 32 bit versions of Internet Explorer 9, Chrome 42 Firefox 12-51 and 52 ESR, or higher
  • Mac OS running Safari 9, Chrome 42 Firefox 12-51 and 52 ESR, or higher
Mobile Support
  • mydlink Lite and mydlink Plus apps for iOS and Android devices2,3
Physical
Environment
  • For Indoor Use Only
Weight
  • 57.7 grams ± 5%
Power Adapter
  • Input: 100 to 240 V AC, 50/60 Hz
  • Output: 5 V DC 1 A (Micro-USB)
Power Consumption
  • Maximum:  4 watts ± 5%
Temperature
  • Operating: 32 to 104 °F (0 to 40 °C)
  • Storage: -4 to 158 °F (-20 to 70 °C)
Humidity
  • Operating: 20% to 80% non-condensing
Certifications
  • CE
  • CE LVD
  • ICES
  • FCC
Dimensions (L x W x H)
  • 3.5 x 3.8 x 9.2 cm
Package Contents
  • DCS-8000LH Mini HD Wi-Fi Camera
  • microUSB power adapter
  • Quick install guide
Wireless Range Extender Built In :No
Built-in Speaker :No
Motion Detection :Yes
Sound Detection :Yes
Built-in Microphone :Yes
Dimensions (Size) :37 x 38.1 x 95 mm
Wireless Connectivity :802.11n
Indoor / Outdoor :Indoor
Video Compression :H.264
Night Vision Range :B&W 5m
Camera Type :120 degree view
HomeKit (Apple) Enabled :No
Maximum Video Resolution :1280 x 720 @ 30fps
Warranty :1-Year Limited Warranty
Night Vision :Yes
Motorised Pan / Tilt :No
ePTZ :No
MicroSD Card Slot :No
Digital Zoom :4x
Two-way Audio :No
Email Notification :Yes
Ethernet Port :No
HIGHLIGHTS
Camera
Hardware Profile
  • Aperture: F2.4
  • Angle of view:
    • Horizontal: 112°
    • Vertical: 54°
    • Diagonal: 120°
  • 4x Digital zoom
Image Features
Video Compression
Video Resolution
Audio Support
  • PCM
Network
Connectivity
Network Protocols
  • DNS client
  • RTP/RTSP/RTCP
  • Bonjour
Features
Event Management
  • Motion detection
  • Sound detection
Browser  Support
Mobile Support
Physical
Environment
Weight
  • 57.7 grams ± 5%
Power Adapter
Power Consumption
Temperature
Humidity
Certifications
  • CE
  • CE LVD
  • ICES
  • FCC
Package Contents
Night Vision :Yes
ePTZ :No
Digital Zoom :4x
Two-way Audio :No
Ethernet Port :No
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DCS-8000LH/Ax
View from the right
Front view
Back view
Left side view
İndir
Destek Merkezi
