ANT24-1801EOL EOS
High Gain Directional Yagi Antenna
Nereden Alınır
Tanımlama
The D-Link ANT24-1801 connects to the DWL-900AP+, DI-614+, DI-714P+, DWL-900AP, DI-714 and DI-713P to extend the range of coverage for the wireless network.
The D-Link ANT24-1801 antenna provides extended coverage for an existing 802.11b wireless local area network (WLAN). The D-Link ANT24-1801 comes with a conversion cable that allows connection directly to the D-Link DWL-900AP+ wireless access point, DI-614+ wireless router, DI-714P+ wireless router, DWL-900AP wireless access point, DI-714 wireless router and the DI-713P wireless router Rev C1 or later wireless broadband router.
This product includes the following items: Mounting Kit, Lightning Surge Protector, Conversion Cable.
The D-Link ANT24-1801 requires an access point or wireless broadband gateways with a reverse SMA connector. The D-Link ANT24-1801 comes with a conversion cable that allows connection directly to the DWL-900AP+ wireless access point, DI-614+ wireless router, DI-714P+ wireless router, DWL-900AP wireless access point, DI-714 wireless router and the DI-713P wireless router Rev C1 or later wireless broadband router.
NOTE: To obtain optimal results in extending wireless range with outdoor antenna installations, it is recommended that professional installer service is consulted for site survey and proper installation.
Genel Özellikler
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
ANT24-1801/Ax
Front view
İndir
Destek Merkezi
