Standarts
- IEEE 802.11b wireless LAN
- IEEE 802.3 10BASE-T Ethernet
- IEEE 802.3u 100BASE-TX Fast Ethernet
Reception Sensitivity Nominal Temp Range
- 22Mbps: 10-5 BER @ -80 dBm minimum
- 11Mbps: 10-5 BER @ -79 dBm minimum
- 5.5Mbps: 10-5 BER @ -83 dBm minimum
- 1Mbps: 10-5 BER @ -89 dBm minimum
Data rates
- 22Mbps
- 11Mbps
- 5.5Mbps
- 2Mbps
- 1Mbps
- Auto fall-back
Frequency Range
- 2.4 - 2.4835 GHz
Modulation Technique
- PBCC
- DSSS
- 11-chip Barker sequence
Data Rate & Modulation
- 22Mbps/8.5db: PBCC
- 11Mbps/4.5db: PBCC
- 11Mbps/8.5db: CCK
- 5.5Mbps/1.5db: PBCC
- 5.5Mbps/5.5db: CCK
- 2Mbps/3db: Barker
- 1Mbps/0db: Barker
Operating Channels
- North America (FCC):11
- Canada (DOC): 11
- Europe (ETSI): 13
- Japan (MKK): 14
Antenna
Detacgable external omni directional antenna (reverse SMA connector)
Operating Range
- Indoor: up to 100 m (328 feet)
- Outdoor: 400 m (1,312 feet)
Data Security
- 64-bit, 128-bit and 256-bit WEP encription
Wireless LAN to Ethernet Interface
RJ-45 10/100 Mbps Fast Ethernet ports with MDI/MDIX
Operation Modes
- Repeater
- Access Point
Configuration & Management
Web-Based through Internet Explorer v.6 or later, Netscape Navigator v.6 or later, or other Jave-enabled browsers
Diagnostic LEDs
- Power
- WLAN
Power Input
- DC 5V, 2.5A
- Through external power adapter
Dimensions
90 x 82 x 40 mm
Weight
153 gramms
Operating Temperature
0 - 55 C
Storage Temperature
-20 - 75 C
Humidity
Up to 95% non-condensing
EMI Certification
- FCC Class B
- CE Class B
Safety Certification
UL
